Yes, but it won’t be possible to get a 3D preview of the rounded out top portion of the molding if using Carbide Create — it doesn’t support cove radius endmills:
One question is what sort of stock will you use and how will you work it? Options are:
- a single piece of wood which you remove a fair bit from
- smaller sections which are pieced together which will allow more efficient stock usage
First thing is drawing up the outline of the design, and a profile of the molding along w/ dimensions — if you can provide a rough outline of the latter we can apply it to the former which would be easily drawn up from your photo:
