Hello, I"m a new Shapeoko Pro owner, so forgive me if you are disturbed by my question. I’m trying to understand the spindle speeds. The Carbide3 website saya that the spindle runs 12,000 - 30,000 RPM. If I understand this correctly, when my spindle is set at “1” is running at 12,000 rpm. If I set it to “6” it runs at 30,000 rpm. In fact, I ran a spread sheet to figure out all other speed seting based on the number on the spindle:
1 - 12000
1.5 -16500
2 - 18000
2.5 - 19500
3 - 21000
3.5 - 22500
4 - 24000
4.5 - 25500
5 - 27000
5.5 - 28500
6 - 30000
So today I was running a Nomad End Mill (0.125 inch) #102 and Vcarve Pro set the spindle speed at 6200 rpm. But I can’t get to 6200 rpm the slowest it goes is 12000, almost twice the speed. So what do I do? Do I run it until it fails? Do I increase the feed rate? Suggestions?
In woods higher cutter RPMs definitely work and the Pro is rigid enough to not have a problem, especially on such a small cutter.
You can use @gmack 's calculator sheet to work out sensible values
For slotting in wood I would run that 1/8" at (minimum) 20,000RPM in my spindle, 1,000mm / min feed rate, that’s 0.03mm/tooth, 3mm deep. I’d push it more normally but a full engagement slotting is hard on the cutter and it’s only small.
You can go faster, for MDF no reason not to go to full RPM, just don’t let the feed per tooth go much smaller, you’re just wasting cutter life and making dust then.
You can also probably cut the slot deeper than the 3mm, but I’ve never pushed the 1/8" cutter, I only use it for detail finishing after roughing out with something larger. A 1/4" in the pro should slot at least 10mm deep and be quite happy.
Double the feedrate to match the doubled RPM, to maintain the same chipload. But mostly, ignore Vcarve default settings and start from CC database values instead?
Or if you feel like it learn about how to determine feeds and speeds yourself?
IFAIK Vcarve Pro doesn’t provide any meaningful speeds and feeds guidance, even for the tool databases from Amana and Whiteside. 6200 rpm is really crazy. You can get more out of your machine by running the spindle at the highest speed (30.000 RPM) as long as you keep the feed rate above 0.001" per tooth (IPT).
