For the cleanest carving, you’ll want to have a stepover that’s at most 1/4 the diameter of your bit and preferably the smallest you can live with. For a 1/8" bit you’ll want a max of 0.31 and if you can live with the time to do it at 0.1 that would be better. You can probably increase the feed rate of your cut along with the RPM to compensate for the increased chip load. You’ll have to see based on how it’s cutting, though.
It’s not exactly the same but I did a test to see what stepover would work best for 3d carving with different ballnose bits I have. You can see the differences between them pretty distinctly Figuring Out The Best Stepover %
It is inevitable to see lines when machining. Decreasing the stepover will help. You must factor in the runout of the spindle + the length of the tool and also whether the router is perfectly in tram or not. The larger the stepover, longer the tool, larger the diameter, etc are all going to magnify these imperfections. Also a downcut endmill generally will leave a clean surface on the raised edge of a pocket, but leaves the potential for a rougher surfact finish on the floor as you are pushing the chips down and re-cutting.
