I’m new to this, and I have created a file for inlay. I have followed many examples online, YouTube’s Carbide Create instructional videos, and other sources. I do NOT have a bit setter, so I’m doing the separate cut program files and re-zeroing the Z-axis only. Following instructions as provided by several others very closely. The program starts and runs the first little part and then loses its mind and goes off course.
I tried cutting the #13 as an inlay just for practice. The female side of the cut runs just fine. Changed the bit, loaded a new program, had the machine set back to the zero preset for X and Y, I rezeroed the bit on the Z axis only. Start program. It runs the 3 almost perfectly, goes to the one, runs the front side of the one, and then goes across the top of it and continues about 1/2" beyond the back edge of the one.
I have made sure I have the right machine loaded in the system. i have cleaned every roller and lubricated everything according to the manual, and checked for any loose set screws. I can’t find anything wrong with it anywhere in that area. So I feel its in the programming??
I’m using the free version of Carbide Create and Carbide Motion. I don’t want to spend the money to upgrade until I figure this out and make sure this is something that I can do. I feel really stupid right now; I’m frustrated and angry that I can’t figure this out.
Any help would be appreciated.
If there is any information that I left out that you may need to help, I’ll gladly provide it. just may take a little time to respond. I posted on here before and was trying to do an inlay on a cutting board for a wedding present and had to scrap that because I couldn’t figure it out. Letting my wife down on the present she wanted to give a close friend. There was some great advise and I went thru all the checks and still can’t get it.
Shapeko 3xl, bought from a retired engineer who barely used it.
I had already started flattening the overun off so i drew a line where it overran the endmill run did fine the vcarve first pass ran perfect on the #3 and uo the fron dise of the #1 then went wonky where the oencil mark is beforeni could stip it where it ends.
I appreciate your response and help with this. Feel my next step may be to order a tune up kit and go thru that and makensure everything is perfect there. Ive double check everything so i dont think thats it, but ive run out of ideas. Was hoping someone could lokk at this and say they know exactly whats wrong. Other than im just an idiot. Lol
I’ve found the best thing for such difficulties is to prepare an exhaustive checklist in the Notes for a given file/project.
Start with Stock prep and continue through Setup and note details of each operation and the expected state at the end/what is necessary for the next.
The second big help is just budgeting for 3 times the stock needed for a given project:
inexpensive (scrap if possible) analogs for an initial prototype — if cutting maple and walnut, I’ll use poplar and cedar
buy twice as much stock as-is needed for the main project — sort it into good enough for a test cut
and the nicest stock for the actual part which is only cut once one has two successful cuts (in terms of lessons learned) under one’s belt
The penultimate thing is to break any technique down into the basics and set up a project which trials exactly one aspect of the technique and to cut only that and iterate until everything about the technique makes sense.
The last thing is to consider all the possible ways things can go wrong and put processes in place to avoid each possible error:
setup wrong? Put a description of the setup in the exported toolpaths file. Re-check setup/zero/origin by loading the source file and jogging around — I’ll even measure the rapid for the first cut in Carbide Create and manually jog that distance/direction for an initial sanity check
wrong tool loaded? Never separate a tool compleatly from its case and have a special area for the case for the currently loaded tool and nothing else ever goes there
cuts in wrong position? Always try to order toolpaths so that interior cuts are made first — that way if a correction is necessary there may be material left to allow for it
something mechanically interferes? Always watch the initial pass all the way through the machine moving down to make the second.
Inlay Plug Mode should only be used for the male/plug portion of the inlay.
For the female side, use a start depth of 0.0, and a Max Depth the depth you want (0.200?)
If you measure the letters after cutting the way you have it, they should all be about 0.230" too big, and 0.300 deep.
On the male side, use Inlay Plug Mode, and try a plug depth of 0.150, and a top gap of 0.100.
Assemble them & measure the actual top gap. If clamped, it will likely be a bit less than 0.100.
Use the result to fine tune the programmed dimensions to get the result you want. Probably an actual plug depth of about 0.180 - 0.190 to leave just a bit of glue gap.
In your case, I would first check the toolpath carefully, especially the point where the cutter moves about 1/2 inch beyond the back of the number 1. Since you are changing bits and manually setting the Z-axis again between programs, even a small difference in the Z-zero position can affect the result. A Carbide 3D BitSetter can make this separate-tool workflow much easier by automatically measuring the new bit after a tool change. It will not correct an incorrect toolpath, but it can remove manual Z-zeroing as one possible source of the problem.
. The mirroring results in a backwards13 and the outline will then give you the plug which should fit into the pocket and make sure you have the backwards 13 and the mirror vectors selected when you do your v-carve tool path
Cut them out and press them into the pockets. This assumes you’ve got your depth numbers correct based on other comments/suggestions posted. Not sure if this was a direction this discussion needed to go, but thought I’d bring it up.
[quote="Thats good to know. Do you have a link to something like that?”
I do not have a link if thats what you’re asking me. All you need to do is setup several toolpaths and make the cuts and then measure the cuts to see if they are accurate per the tool paths. Cut some circles, triangles, rectangle and squares for example.
As noted, for the inlay, you will similarly need to use a larger tool, and you will need to mirror the design, and you will need to add geometry around it:
