T-Track Kit Install Help - S3 XL
I am closing out the assembly of a Shapeoko 3 XL, and am unable to find instruction on installation of the T-Track kit that was an optional purchase with this machine. Any help, such as a PDF or written instruction, would be greatly appreciated.
Linked is the referenced T-Track kit: Carbide 3D Shapeoko XL T-Track and Clamp Kit | MatterHackers
I never used the Carbide track kit but a couple of things from installing my third party T Tracks.
I fitted mine on top of the machine MDF baseboards and simply cut the top spoilboard into three parts to fit between the T Tracks.
In terms of attaching the T Tracks to the machine, I went through various attempts with screws, threaded inserts etc. installed from the top, they all failed so I ended up drilling for M3 through the Shapeoko baseboards, taking them off and installing Tee nuts from the back so that the tracks could be held down reliably.
HTH
I wrote a bit about my filler strip setup at:
