I’m having an issue with using texture tool path. The tool path does not stay inside the desired lines. Some go past some are short of mark.
Can anyone offer me a fix? I looked but did not see any questions like this on boards.
@Engine1 , I don’t use CC but envision the texturing works like cross-hatching in other CAD programs. Is is possible that your boundary path has an overlap or gap (i.e. isn’t a closed path)? Please forgive me if I’m making a false assumption… ![]()
I’m using a square with the letter C in side the box very similar to the one in tutorials. I’m not aware of any breaks.
The Texture toolpath works to the center of the tool, so will extend beyond geometry by the radius of the tool used.
If you wish for it to be constrained, inset the geometry in question by the radius plus a suitable safety margin.
There was a similar thread this past spring.
If you have a problem with a specific file, it’s best to post it here.
That makes perfect sence:man_facepalming:
. Thanks so much!!!
