I remember a comment about G19 plane changes for arcs being a factor. In lieu of lead in, try using a ramping move. Or try setting vertical lead in radius to zero, and only using horizontal. I can’t replicate your error on Shapeoko with your last 2 files. Will test on Nomad tomorrow.
Out of curiosity, can you provide the machine coordinates of where you’re zeroing to start the program? Wondering if the initial condition of the steppers and positional resolution may play a factor.
(Jog to your origin, then click on the “Position” label over the readout on the left.)
in checking back in, I still think I like the interim solution of disabling the PLANE_ZX and PLANE_YZ in my post the most, and have had no issues since
Pretty sure this one is a Motion issue, not a Fusion 360 or grbl issue. None of the trouble files here that I’ve tested cause issues with other senders. I have only seen those errors on this Forum, and I use Fusion 360 pretty regularly.
Actually, with this setting it just interpolates the arc motion to linear motion and gets on with it, and does lead-ins and outs just fine—albeit with larger gcode files. Not really a problem as far as I see it at the moment.
Sure they’re not “true” arcs, but with this kind of tool and equipment, doesn’t seem to cause any problems.
That’s what GRBL does on board anyway. I just think there’s something in Carbide Motion causing the errors. Some of us are ok modifying post processors…it might turn others away from Fusion.
