Thoughts on this?
So I cut this out tonight, thickest wood I’ve done so far (only done 1/4" or thinner until this 1" piece) but on the final cutout the machine shut off and disconnected (literally at 99.8%) but it was easy enough to finish it with my Dremel and some sanding. I think the 1/4" bit was rubbing the walls inside the outside cutout. So, the question is, what is the proper fix so this does not happen in the future?
My thoughts are either a bit with longer flues (mine was only 3/4" while the cut depth was just a hair over 1") or somehow make it cut wider (pocket) so there it does not get pinched between the 2 walls??
In other words I believe it over powered the spindle motor due to friction though it did not sound bad or anything and did not burn the wood. And I was keeping it vacuumed out well so the fact I ran out of flute is my (NOOB) best guess. Oh, and the settings were all the default for the bit that CC decided to use.
Well, it did it again on cutting out the lid (only .75" thick) so I think my flute length theory is dead.
I am letting CC make the settings but maybe I need to change them?
DPP 0.009
Stepover 0.113
Feedrate 75.000
Plungerate 12.500
RPM 8333.000
I still don’t know how to calculate best settings so maybe someone can give me a clue (or just tell me what to change to what).
These were both hardwoods and the dark one is walnut but I don’t actually know the other one but it’s a quite a bit softer than the walnut.
Only other mistake I made was the gap between the lid inside lip. Gave a little to much so the lid wiggles. I want to make and sell these so I need to get educated on proper cutting for this stuff (the lid I can figure out) but the settings for cutting I need help with.
BTW I found a DIY food safe oil/beeswax recipe I really love for food contact wood. If anybody wants it let me know.
Oh, and yes I know the grain in the lid is going the wrong way but I used a scrap I had and it was just slightly larger than the lid so I had no choice.
Lovely boxes! (I’ve been working on an automated generator fo such boxes: Fitted box design generator underway and posted one to cutrocket recently: https://cutrocket.com/p/5c9fb998c0b69/ and having the rounded bottom is a feature I’ve just added)
Please see:
There’s an interactive version at:
https://public.tableau.com/profile/willadams#!/vizhome/Carbide3DCNCFeedsandSpeeds/Sheet1?publish=yes
See https://www.youtube.com/watch?v=S9bceJxpqG0 for concepts on this and see the series #MaterialMonday: #MaterialMonday on YouTube for specifics.
You should test feeds and speeds in a piece of scrap using the technique at: https://precisebits.com/tutorials/calibrating_feeds_n_speeds.htm
Another consideration is Climb vs. Conventional Milling and tooling engagement — where possible avoid slotting and add geometry and cut as a pocket (Adding geometry to cut as a pocket with a finishing pass ).
Hey! My first impression was “he’s running the grain the wrong way”. Then I thought about it. If structural integrity was an issue, indeed you should run the grain long-ways. But the thickenss and size of your piece suggests this is not so. So run it however you want.
When we had wood floors installed a couple years ago, the decision was whether to run N-S or E-W. I thought of making a joke about running at 45°. Before I could crack it, the installer suggested the very same plan. We did it and are thrilled.
Looks great! I think you already answered your question - the Nomad spindle motor does not have a pile of power and spinning the (relatively large) 0.250 end mill puts it even further into the red. If you have a long deep slot, particularly towards the bottom when the walls start to deform in ever so slightly you will be using a lot of power just to overcome the friction/cutting area and probably your piece slowly pushed it over the edge into shutdown. The answer is indeed to make that slot a bit wider with some stepover such that the friction/cutting area is reduced at any one point in time. Havent used CC for quite a while but suspect pocket is indeed the way to deal with it.
And whilst I think about it cutting past the flutes tends to block the chips from exiting the flutes (particulalry in slotting) so if you are thinking about doing a large number of these an end mill with longer flutes is probably a good idea from a cut quality/tool lifetime point of view.
I think I will switch back to an 1/8" endmill (just for the outside cut) and make a pocket cut for this but I still need an 1/8" endmill with 1" flutes I guess. Any recommendations?
BTW the whole reason I got the 1/4 endmills was to use a ball endmill on the inside edge to have a radius bottom around the edge and it did work perfectly for that. And the rest of the inside was a 1/4 flat to pocket out the rest and that also went without any issues.
Or, is it OK to use the 1/4" endmill (.75" flute) if I do a pocket on the outside edge? Or will it still rub abd cause too much friction?
I still have lots to learn and am greatful for this forum and it’s members for helping me.
1/4” end mill should be fine if the outside pocket is wider than 1/4”!
Thought I would post an update for anybody interested.
I thought I had the issue licked as I mad the outside cut a pocket and on the first one it finished without any issues. But the next 3 tries it failed again and again, I tried slower feeds and such to no avail and I was watching it closely one of the times when it stopped and it was moving in a straight line and just bit into the wood and stopped dead, it really didn’t seem like it was struggling, no slow downs on 90% and not even touching the walls when it happened. I could easily move the spindle motor with 1 finger where it stopped.
I came to the conclusion that the 1/4" bit was just too much for the machine period.
The only reason I used the 1/4" bits was to get a 1/4" radius at the bottom inside edge (which it did beautifully) and I just figured why not use a 1/4 flat end mill for the rest at the same time. Turns out that was a mistake.
So, for now I am switching back to my trusty 1/8" and I will do without the fancy inside radius. BTW I cut 2 with the 1/8" last night and both worked flawlessly.
The 1/4" endmills are supposed to only be used in softer materials such as Renshape.
You could use a 1/8" endmill and leave a set of steps on the inside, then make a finishing pass w/ a 1/4", or just model the whole shape and use a ball-nosed 1/8"
There are a couple of endmill sizes in-between 1/8" and 1/4" — 3/16" obviously, but also 4, 5, and 6mm — perhaps one of them would make a suitable compromise?
How many flutes are your cutters? Switching to single flutes will minimize load per revolution while still keeping chipload up.
For a 10,000 rpm machine I would think its better to have the higher sfm a 1/4 will be running. Datron makes some really nice single flute ball mills that work beautifully.
In my experience with a similar wattage spindle is that large endmills are very possible to use if load is adjusted accordingly. Adaptive load cam really helps with this. I was able to run a 6mm in aluminum so don’t give up!
