Lovely boxes! (I’ve been working on an automated generator fo such boxes: Fitted box design generator underway and posted one to cutrocket recently: https://cutrocket.com/p/5c9fb998c0b69/ and having the rounded bottom is a feature I’ve just added)
Please see:
There’s an interactive version at:
https://public.tableau.com/profile/willadams#!/vizhome/Carbide3DCNCFeedsandSpeeds/Sheet1?publish=yes
See https://www.youtube.com/watch?v=S9bceJxpqG0 for concepts on this and see the series #MaterialMonday: #MaterialMonday on YouTube for specifics.
You should test feeds and speeds in a piece of scrap using the technique at: https://precisebits.com/tutorials/calibrating_feeds_n_speeds.htm
Another consideration is Climb vs. Conventional Milling and tooling engagement — where possible avoid slotting and add geometry and cut as a pocket (Adding geometry to cut as a pocket with a finishing pass ).
