Sooo, I pushed my luck a bit too far while experimenting with cutting aluminium (with the #102Z endmill), I got a partial melt before I could stop the job, so I now have a bit of melted aluminium in one flute of this endmill. Does anyone have any advice on how to salvage it with minimal risk of damaging the ZrN coating and/or the flutes ? Some magical household cleaning liquid maybe ? (I have searched a bit and saw the words “lye”, and “pipe cleaning liquid” coming up, but would like to hear about people here)
This cut was a follow-up of this first try that went perfectly fine with:
102Z 1/8" ZrN coated endmill / adaptive clearing toolpath, 10.000 RPM, 762mm/min feed, 0.305mm optimal load, DOC around 0.3"
I then tried increasing the optimal load to 0.4mm, the cut started just fine, but I had mistakenly set my air jet to a lower flow than on the first try, and after a while, I got an accumulation of chips in a deep/corner area, and that’s when I had this melting issue.
I have rerun this job just now, with more air and a little spray of WD40 now and then, and it went perfectly.
Good question, that I had myself since I started using fusion360 like a week ago. Reading around I understood that yes, it is basically the chipload, that fusion tries to keep constant when using an adaptive toolpath. Fusion gurus will probably jump in to explain subleties of optimal load better!
Chipload is chip thickness per flute per revolution. Fusion doesn’t take into account chip thinning, this happens when radial cut falls bellow 50% diameter. Use a calculator to determine actual chip thickness
So is optimal load the size of the bite at the start of entry of the tooth into the material, but differs from chip size since the chip gets thinner and thinner as the tooth moves out of the material ?
I have nothing great to add except if a little piece “looks” like it might be easy to grab with a pair of pliers, and your eyesight is poor like mine, don’t just “gopher it!”… Don’t ask me how I know that doesn’t work, meh
I’m not going to be doing any production runs or even a lot of metal work, so I’ll probably end up using the formulas and figuring out the feeds/speeds/DOC/stepover stuff manually.
Just can’t justify the cost of g-wizard when the CNC stuff is simply a playground for me.
