Good morning.
Kind of a newbe question.
I am curious about something when creating toolpaths. If I have 3 separate tool paths and 2 different bits do I have to disable the bit tool path I am not using and run the tool path then enable it after the first cut is done?
For example I have a 1/4 EM path and a 30V bit path.
Do I have to disable the tool path for the 30V if I am running the 1/4 EM tool path. Then enable my 30V after the 1/4 Em is done cutting or does the machine know to stop for a tool change.
Thank you
If you have a BitSetter, then it will work to send the file with multiple tools.
If you do not have a BitSetter, then you will need to disable all but one tool each time the file is sent.
For a walkthrough showing this see:
Thank you very much. That is what I was thinking.
