Pete
(Luther Peterson)
July 1, 2019, 11:55pm
1
When I highlight all the text and then the border for a pocket with raised lettering the tool path is not recognizing one of the letters and I can’t figure it out. I know it’s probably something simple that i’m not doing.
I highlighted all
but the tollbooth wants to cut it out. Thank you for you help in this matter.
mikep
(mikep)
July 2, 2019, 12:06am
2
The path is likely open and it’s cutting “both sides” of the lines…
Pete
(Luther Peterson)
July 2, 2019, 12:29am
3
I added the Mrs. as text all together.
WillAdams
(William Adams (Carbide 3D))
July 2, 2019, 12:51am
4
The problem is the problem M overlaps one of the rings.
Pete
(Luther Peterson)
July 2, 2019, 1:10am
5
What can I try to fix this problem to make multi level text?
WillAdams
July 2, 2019, 1:19am
6
For a work-around to do this please see:
I’ve been using a different hobby cnc machine with it’s own software for a number of years. The attached picture is an example of a plaque that I create with this software and machine.
I am trying to decide between purchasing a Shapeoko XXL or a X-Carve 1000x1000. I’ve gone through all the pros and cons of each machine. I’ve done a ton of reading on both machines forums. The “usability” of the base software that comes with each machine will play a part in my decision.
I’ve used both Carbid…
system
(system)
Closed
August 1, 2019, 1:19am
7
