Trying Bit Zero again
The probe worked fine, set for lower left. But when i started the project, the bit went too deep. I ran the same project file set for middle and used the paper technique and everything worked fine. here is the file…the only change was lower left vs center.
Apple test 2.c2d (124 KB)
…and Bit zero used for lower left, paper technique used for middle.
See:
not clear on what you do if it is wrong. clearly the z-axis config is wrong.
For the configuration difficulty, reconfigure:
https://carbide3d.com/hub/docs/shapeoko-setup/
here is the config file. do you s
config 10-12-2024.pdf (31.8 KB)
ee any issue?
and here is the CC file…
Apple test 2.c2d (96 KB)
