Trying to make lines like a measuring tape
I’m trying to create a fish measuring board so there needs to be large and medium sized lines place perfectly, *t keeps telling me EMPTY TOOLPATH . what am I missing? Thanks in advance.
upload your c2d file here so that we can have a look
Open/unclosed lines (indicated by being magenta) can only have Contour toolpaths associated w/ them — you’ll want to use a no-offset contour.
I had to create a thin rectangle that was a 1/16" wide . I thought I could just draw a line and tell it to cut the path of the line.
You can just draw a line and tell the software to cut that — it’s what a Contour toolpath does — you’ll want one w/ No Offset.
I used open vectors for lines, a contour toolpath with no offset and a v-bit.
https://community.carbide3d.com/t/what-did-you-cut-on-your-shapeoko-nomad-today/31274/1299?u=ed.e
Drop this in your library folder
tape_measure
Contour / No Offset the lines. VCarve the numbers.
