I was another lucky enough to beta these. They are freaking awesome, and quickly became my go to clamps. I have used them for working holding while surfacing a work piece, V carving, and pocketing with both upcut and downcut endmills. They just freaking work! As (themillertree) said; "do yourself a favor and buy these!
I used the clamps as side stops with the grub screws for work holding for this.
Such a top class design, the angled grub screw and toothed flat end is an awesome idea!
I was thrown by the dustboot design, I was definitely expecting a z-independent design. however hearing about the performance of the C3D boot, and the simplicity of it, i’m keen to try it.
I opt for the stainless steel vs the aluminum version. On this pic, you will notice that the bottom of the screw head digs into the aluminum recessed shoulder. I find this to be problematic long term. A washer between the screw head and clamp would resolve this issue but I doubt a washer would fit in the clamp.
Totally agree about the grub screws they are genius and make workholding straightforward especially when the thing you are making is going to be cut out from the stock.
@Luke I have a beer with your name on it or a coffee if you prefer:)
Sure. They are just washers though. I made them a tight fit for 1/4-20 SHCS for the ID and about .010 smaller that the clamp slot for the OD.
I’ll take some pics and give measurements when I get home.
The washers definitely help. Keep in mind, these are prototype clamps, and the slots were too small for 1/4" hardware. The aluminum clamp in the first two pictures, the slot was opened up by hand with a Dremel. If you really tighten down on the aluminum clamps without a washer, they can gall pretty bad. The washers pretty much eliminate the galling.
I cut these at .255 ID, .405 OD
