I was running a project for about 5 minutes when it stopped working, bringing me back to the screen below. I thought maybe I had stopped it somehow because I was on my Windows laptop then. So I reran it and it stopped about 20 minutes into it. This time I was nowhere near my laptop. Iām at a loss. Any ideas?
Contact us at support@carbide3d.com ā usually this sort of disconnect is EMI and we have a quick check and a 10-step program which works for most folks.
If it is EMI as @WillAdams said, this is what I did to solve the issue.
Grounding your Shapeoko - CNC Machines / Shapeoko - Carbide 3D Community Site
Just sent it. Thank you.
Support will help you but in the meantime follow what @Zman suggested. You do need to separate a power off from just a loss of communication. The most usual problem is static electricity sparking and causing the controller to lose communication with the computer.
There is a light on the power supply for the Shapeoko. When it disconnects check that the led is still on. If it is is then it is not likely a power outage but a loss of communication.
Static is a problem and worse during dry conditions. The moving router bit, moving air in dust collection and cutting the wood or plastic is a good static generator. Check your local weather and see what your relative humidity was today. If it is low I would suspect static. Well it is almost always static causing this.
I have noticed static electricity around the hose to our dust collection. Will an anti-static hose do the trick?
It will help. I use a Fulton Hose which I got from Peachtree ā apparently they are only an Amazon storefront these days.
Woodcraft has a similar one, which I bought, but never have had occasion to use:
Thank you. Ordering now.
As @WillAdams said that will help but you must do more. See the link from @Zman for a complete solution.
Okay, I might as well be reading a foreign language. Lol! Can you link the parts I need and is there a video I can watch instead?
Support is great on this subject. They can do a video link to guide you as they look at your machine with you.
