On on a MAC
I am supposed to be able to select a shape and then select a second shape by holding down the Command key. This does not work and it just selects one and deselects another.
Thoughts?
On on a MAC
Thoughts?
Howdy Dave. Use the Shift key to multi select. Hope that helps.
As @Lonnie_Mac noted, this is now shift — it used to be command/control in older versions.
Please see:
That did it. Thanks.
Thanks. They really should update their video tutorials. They still say Command. It’s been driving me crazy.
I have noticed in my Windows CC 4.74 that when you select objects for Boolean operations and you Control Z to back out of something the order swaps on the objects (2). Has anyone else noticed this behavior.
To be clear if you have two objects, A&B. You select A first (solid orange line around object) and use Shift to select second object B (broken orange line). You do a Boolean operation but do not like the result and hit Control Z, Object A now how the broken orange line and Object B has a solid orange line.
I asked before and this was done on purpose. The most common mistake is to have the order inverted… so ctrl z now fixes that up
