I am new to CNC, I have the nomad 3 and used carbide create when I add the 3d finish I keep getting this pattern across the piece. I had hoped it was a simulation error but it is actually drilling almost all the way down to the bottom in this uniform weird pattern. I can’t seem to get it togo away. Can someone help. I will gladly provide more details, but being new I’m not sure what all you need to help me diagnose the problem. I create another 3d piece prior to this one and had no issue with the same settings.
if it’s just a simulation artifact it won’t be in the actual cut.
this is technically more complicated but there’s a tool called “camotics” which is open source and is another way to simulate toolpaths… worth checking that perhaps.
Looking at the time it’s estimated to take I still wonder about the toolpath though… that’s a long long time.
