64Lane
(Wayne Hunter)
May 11, 2021, 8:44pm
1
Hi, I have a Carbide Motion Control board version 2.2. Can I upgrade to a newer version ? Reasons being I just purchased a BitProbe 2 and has a single 3 pin connector. My board had a 2 pin and a single pin I use to my Carbide touch probe. I appreciate any help here. Will a newer board still work in this
sincerely Wayne Hunter
Note: the Shapeoko 3 is the standard size .
WillAdams
(William Adams (Carbide 3D))
May 11, 2021, 9:46pm
2
Yes, please see:
You should never need this, but if you do, it's a replacement Carbide Motion PCB for Shapeoko. Â It includes: Atmel 328 running GRBL 4 Stepper Drivers (X, Z, and double Y drives) USB Interface Comes in two options: Stand-Alone CM Board (The...
PRICE: From $ 99.00 USD
but we should have included an adapter cable to make any accessories work.
This might be of interest:
If you’re comfortable with some small electronics work, I made a PCB that breaks out the switch pins to screw terminals. I “future proofed” it by adding a 5V rail and some PWM pins. You could easily remove the connectors on the prox switches and use the screw terminals. I’ll have to track down the extra boards, but it’s yours if you want one.
It mounts directly to the 12pin connector on the board. The controller cover won’t fit anymore, but yours is old enough to look a little used. …
I have some extra somewhere.
system
(system)
Closed
June 10, 2021, 11:34pm
4
