Vacuum Hose Support File
Hi - I know this has been discussed but does anyone have a file for vacuum hose support on the SP Pro (Z-Plus)?
Thanks,
Mark
See if there is a suitable file at:
Thanks. As I don’t have access to a 3D printer I was hoping I could find a CAD file here. I thought I saw some posted awhile back but can’t seem to locate them.
I made one using Alibre Atom. I have a polyjet printer at work which is a high end 3D printer however while the prints are solid they not the strongest so my model is probably a little thicker than what would be needed if you had access to a filament printer. It just sets on top of the Z stepper motor. Made for a 2.5 hose but it is a little tight.
Thanks. To clarify, I’m wondering if anyone has a file that can be used specifically on a CNC router?
Anything that can be machined on the CNC, as I do not have access to a 3D printer?
Perhaps design something which could be cut in pieces and would fit together?
Alternately, get the part printed at Shapeways?
