Vcarve goes too deep
The basic points of adjustment for a machine are:
Also feeds and speeds may be a consideration: https://docs.carbide3d.com/support/#tooling-support and see https://www.youtube.com/watch?v=S9bceJxpqG0 for concepts on this and https://www.precisebits.com/tutorials/calibrating_feeds_n_speeds.htm for a testing technique and see the series #MaterialMonday: #MaterialMonday on YouTube
Beyond that it’s usually a matter of ​calibration and squaring the machine c.f., https://www.youtube.com/watch?v=V9E3VEYlfwA and https://www.youtube.com/watch?v=P4VverLXpCI and http://docs.carbide3d.com/shapeoko-faq/how-to-calibrate-the-machine-for-belt-stretch/
Troubleshooting concepts:
To eliminate the software, please check it in a 3rd party previewer such as CAMotics: https://camotics.org/ ​ ​The machine is able to move based on: ​
  • impulses from the stepper driver — usually if they don’t work right there are horrible noises
  • sent through the wiring — check the conections and wiring — if you or a friend have a multimeter use it to check for continuity
  • received by the stepper motor — these almost never go bad
  • which rotates the motor shaft — check that this is true and not bent
  • which rotates the pulley — check that it has two set screws at least one of which is on flats and that they are secure: https://docs.carbide3d.com/shapeoko-faq/shapeoko-3-how-to-check-the-pulley-set-screws/
  • which pushes/pulls on the belt — make sure that the belt tracks true through both the pulley and the idlers and is in good condition, secure at appropriate points and well tensioned
  • which moves the machine along the V rails guided by V wheels — make sure that the latter are properly adjusted https://docs.carbide3d.com/support/tensioning-eccentrics/ and the former clean and in good shape
