Is anyone aware of whether there is a commercially available device (either plans or an actual device) that screws into the existing Shapeoko Pro nuts?
I want to make some box joints which don’t have gaps (hence the need to hang my workpiece vertically).
I am aware of a few discussions but not aware of whether successful contraptions exist.
An ancillary question is whether anyone has discovered the best tenon/mortice tweaks for a tight fit. In other words, if I am doing 1/2 inch tenons, would the mortices need to be 1/64th wider? I work in metric so same question can be answered in mm.
Hi Patrick
Can you drop me a DM with some details and pictures of what you are looking to achieve with the project?
I use a “kiss” fit where things are cut to the ideal size – usually they “just fit” (but calibrate first if using a belt-drive machine)
https://community.carbide3d.com/t/cutting-boxes-and-a-new-toy/66302/10
and have done mortise and tenon:
as well as various other joinery designs — in particular, blind miter box joints which do not require a fixture:
If you’ll let us know the specifics of a box design:
- dimensions — height, width, depth
- stock thickness
- desired features: lid, &c.
and if you’re willing to purchase a narrow V endmill which matches a smaller endmill such as our 1/8" #102 I’ll gladly walk through working up a design with you.
Not commercial, but I put a design up on Cutrocket:
Helipaddy
Look on youtube for the jig made by John Clark, it may not be what you want but it’s worth the visit.
