Following directions in the video and it wants me to set the Z position. I’m hitting the z- and it’s going super super slow. Is there a faster way to do this?
. I figured out the increment button. Never mind
For some notes on this see:
Whenever you start up CM the default is the slowest speed. Likely a safety default. Every time you start up CM it will go back to the lowest speed. It is aggravating but you get used to it,
