VFD Spindle doesn't spin
Display flashing 0.0.
Button on front lit red.
Will spin manually.
When I start job, as it reaches the point where it stops and spools up, it won’t spin, but will continue as if all is normal.
All thoughts welcome.
@P1nikitas
Go over all connections again to double check. There was a case of not installing the pin connector on top of the spindle recently.
TY. just did, and no change…I’ll start a ticket with the good folks at Carbide3D!
@P1nikitas
Spindle selected in setup?
I had a similar issue after I installed my new 65mm spindle.
https://community.carbide3d.com/t/new-spindle-and-vfd-issue/99749
Disconnecting all cables and power to the VFD letting it sit for a while then reconnecting solved my issue.
Did you try the second switch where the power cord plugs in? I had that issue lol
Thanks, all! I’ve tried every combination known to man. I removed the front panel of the spindle controller, and on the circuit board in the back is a red light illuminated. I’ve taken a picture and sent it off to Carbide 3D. We’ll get it all sorted tomorrow!
