I am building my S5 and I bought the 65 mm vfd. I saw somewhere that someone had remote mounted the display off the vfd but not I can’t find it. Has anyone else done this and if so how did you do it. I would like to see the display with out walking around the table since the controller is on the back side of my table.
You just pop out the display with the push buttons on the side, remove the male/male rj45 adapter and can you an rj45 ethernet cable of your choice to connect the display to the VFD unit.
Look for VFD extension kit on amazon.
Thanks for the help.
