I just got my Shapeoko XL up and running and I believe the waste board isn’t level… I attached a photo but it appears to be cutting deeper on one side. Im using double sided tape evenly to hold down 1/16 acrylic sheet.
How do I remedy this?
Hi Joshua,
You will need to surface your wasteboard (= shallow pocketing across the whole surface, ideally with a fly cutter, but a 1/4" endmill will do).
Alternative if you are in a hurry: take a piece of MDF a little larger than your acrylic stock, attach it on top of your wasteboard and surface it, then install your acrylic on top: it should be level (and you can then take your time to explore the various options to surface the whole wasteboard or use a supplementary wasteboard)
please see:
Tips on using different bits. What different bits are used for when designing a project. Adjusting depth of cuts. How to make designs. Example you have a flag and want to add text or a emblem to it. Steps to complete it. You guys helped me out in doing just that. But would be nice to have a place where some hits could be found on how to do it. Any other beginning tips that older users take for granted.
https://docs.carbide3d.com/support/#tooling-support
https://docs.carbide3d.com/assembly/carbidecreate/video-tutorials/#toolpaths
Wow, I am impressed! Great job and idea.
@joshjord what material(s) did you use for the faceplate?? I’ve got an amp that has been sitting unfinished because I need to make a faceplate (silver jubilee clone) and it’s at the top of my list once I (finally) finish getting my XXL all set up with hold downs and dust collection…
Interesting place, all sorts of neat stuff…
I think it is cool that you made the notches go to 11. Everyone knows that 11 is louder than 10.
look up Winston Moy on you tube. he has great videos on the Shapeoko 3
