Greetings for IFCE PECEM.
We made our first design and we want to put it on our CNC MACHINE, can you help us with that?
Should we get a code?
What machine are you using. What version of Carbide Create are you using. More information is needed
What CAD program are you using?
What file formats does it export?
What CAM tool do you wish to use?
I suspect you have a CAD program which can write out an STL, in which case you will need a 3D CAM program. We have two options:
For the latter see:
