Will pay for GCode!
I would like to note that DXFs should import easily — we have some notes on this:
  • it may help to use the OVERKILL command to eliminate any overlapping or intersecting paths before exporting from AUTOCAD
  • if lines have different elevations, use FLATTEN [17]
  • PLINES are intrinsically joined, and should be used where appropriate [18]
  • AutoCAD 2000 DXF format (model geometry only, base model scaling) export from the desired face (not isometric view)
  • 2004 Lines
and we would especially want folks to send files so prepared which don’t import into Carbide Create in to us at support@carbide3d.com (other problem files would be welcome as well).
There was a request for sample files a while back:
not sure what the outcome there was.
Anyway, once the files are into Carbide Create, creating toolpaths ought to be easy and straight-forward:
https://docs.carbide3d.com/assembly/carbidecreate/video-tutorials/#toolpaths
