After installing the bit setter, everything worked fine. The problem is that the x gantry will not jog by pressing the arrow key to the +X location. I uninstall/install carbide motion, it works fine in the -X. Can someone help me?
What do you have the X-axis Travel Dimension set to?
Did you configure the machine?
How are you trying to jog? Are you using a game controller, keyboard, or mouse/stylus/touchscreen?
mouse/keyboard. I just can’t move the gantry in the + position.
Where is the gantry when you are trying to move it?
What do you have the Travel Dimensions set to?
Can you move the machine using the Rapid Positions?
Please write in to support@carbide3d.com
