Hey Team,
I am having issues with the X Axis limit switch. @Samcraft I have seen your videos - extremely helpful, thanks - but even with shimming and amending the position of the sensor more times than I can count I have not been able to get the machine to initialise properly.
The sensor itself is working fine, the light on the sensor, and on the board, and within the settings menu are all detecting as you would expect.
When the carriage moves towards the switch, the light comes on, the carriage stops, the machine finds home and then I get an error stating that the pull off did not clear. After watching the machine, many times, I cannot detect visually the machine moving away from the switch after the light comes on.
Once the initialisation has failed, the limit switch light remains on - if I immediately do another initialise, the carriage moves away from the XA limit switch, the light goes out, the carriage moves back towards the switch, the light comes on, the carriage stops dead, then failure…
I have sent the settings for both GRBL and Travel Dimensions within the settings. I have also sent a support request to Carbide, but being in NZ our times are not exactly aligned so thought that with the wealth of knowledge on here, it cannot hurt to throw to you lovely lot for opinions or thoughts.
Any help would be really appreciated.
Kind regards, Brad
