I am cutting some additional holes for threaded inserts on my Shapeoko’s stock waste board. I’m using these to mount a supplemental waste board. The design has a very shallow outer ring/pocket for the top of the threaded insert and then a deeper hole for the body of the insert.
The hole on the left side of the waste board works as it should.
I even tried re-zeroing the Z on righthand side of the board with no better results. I have noticed before that I sometimes get a very thin layer of material left when I try to cut out designs on one side of the board.
The rails, gantry, and waste board are level. I realize there are multiple things that I could adjust–lots of screws. Is there a best place to start?
If it makes any difference, I have a standard size Shapeoko with a Z-Plus and Carbide 3D router.
I would make sure your file is setup correctly and it is not trying to cut a different height there. Especially if you re-zeroed your Z axis near the problem area. If it does turn out to be a mechanical issue and you want to adjust your machine to get it closer, it is quite the job and it is much easier if you have a dial indicator and magnetic mount. I remove my router and attach the mount to the Z plate. From there you can find how you need to adjust your machine. It will probably be a combination of the X and Y end plates that will need adjustment. EDIT: I just loosen the screws and use a clamp to hold the rail in the new location while I tighten everything.
@nwallace, good point on checking to make sure the file is setup correctly. I checked and it is (would have preferred for you to be right!).
Before I try more involved solutions, I’m going to go through those final squaring/alignment steps in the manual one more time. I did check to see that things are level on the machine, but there’s still a little bit of wiggle room even when the level’s bubble is in the center–and that’s probably enough to throw things off here.
The last time I squared the machine, I did it by myself. I thought everything was okay, but I want to do it again with a second set of hands available to tighten the screws.
So, I re-sqaured the machine and also adjusted the tramming screw on the Z-plus. That seems to have fixed the left-to-right differences. There is a tiny bit of difference front to back, but surfacing the supplemental wasteboard appears to have addressed that.
