I’ve used my standard Shapeoko 3XL intermittently for the past 18 months, with few hiccups. The problem described below is happening now for the first time.
The first operation in my current project is a registration pass, boring 3//8in holes on the center line, passing through the stock and into the waste board. In later cuts I will flip the stock and insert pins into the registration holes to position the workpiece for milling the opposite side.
Here are the settings that I think are relevant:
CARBIDE CREATE
Job Setup
Stock Thickness: (Z) 0.517in (actual measured thickness)
Top
Retract Height: 0.250in
Units: Inches
Toolpath
Contour
Start Depth: 0.00 in
Max Depth: 0.90 in
Pocket
AT THE SHAPEOKO 3XL
Standard Z-carriage. Belt is tight, set screws are tight. Springs attached and healthy.
I first used the BitZero probe at the corner of the stock to set X, Y & Z. When I ran the g-code, X & Y positioned properly, but Z started cutting well above the stock.
So I zeroed the Z manually with paper and tried again. This time Z began cutting about half the distance closer to the stock.
It appears that the first cut starts roughly an inch above the stock using the BitZero probe, and less than 1/2 inch above when zeroing with paper. I’m tempted to say these offsets are the same as the Max Depth of cut when zeroing with the probe, and Max Depth - Stock Thickness when zeroing with paper, but I don’t have actual measurements.
Help?
This is the beginning of the g-code:
(Design File: /Users/larrymartin/Desktop/Projects/Guitar/Working Drawings/
telecaster V7 dxfs/telecaster_v7_20200502.c2d)
(stockMin:0.00mm, 0.00mm, -13.13mm)
(stockMax:530.23mm, 355.60mm, 0.00mm)
(STOCK/BLOCK,530.23, 355.60, 13.13,0.00, 0.00, 13.13)
G90
G21
(Move to safe Z to avoid workholding)
G53G0Z-5.000
(registration)
M05
(TOOL/MILL,6.35, 0.00, 0.00, 0.00)
M6T201
M03S18000
(PREPOSITION FOR RAPID PLUNGE)
G0X31.98Y176.97
Z6.35
G1Z-1.59F381.0
X31.83Y177.14F2540.0
X31.75Y177.27
X31.67Y177.40
X31.62Y177.54
X31.57Y177.69
X31.54Y177.84
X31.52Y178.00
Y178.18
