Hello all, hope someone can help me. When I initialize my machine everything is ok. I install the bit and hit continue and it goes over to the bit setter. Now I zero my x and y and my z axis. Once i zero it I run the program. Now it goes to the bit setter and I assume it measures the bit height. Now I start my program and the x and y are alway dead on but the z axis is hit and miss. Sometimes its 0.250 above the work or .100 above, sometime to deep( it varies). Sometimes I re-initialize a couple of times and finally it work. very frustrating.
If you continue to have difficulties, document step-by-step what you are doing and send it in to support@carbide3d.com and we will do our best to work through this with you. For an example of this sort of thing see:
