Looking to do some custom stuff with a stock SO Pro.
Does anyone know if the Z-plate bolt pattern is available anywhere?
It should be the same as for the HDZ — I drew this up at:
but cut a test to be sure of the fit first.
Sweet thanks I will check it out. To confirm, a PRO doesn’t have the HDZ (neither do I) but it’s the same for both?
(Nice to know before my test cut because I need to take my spindle off after the test cut only to find it doesn’t fit
Also some of the accessories for HDZ say it won’t fit the regular mount. Hopefully that’s more of a “this wasn’t designed for the non_HDZ” as opposed to “the bolt pattern is totally different”
