Z-plus conversion
I’m converting my Shapeoko 3 to z-plus and need to resolve the connection to the controller. Attached is photos of the two connectors. The one on the right is the current connector (belt drive), and the left is the z-plus which I need to convert. I updated this unit about 2 years ago with a new controller and sensors. How to proceed?
Parts for the SO3 are listed at:
https://shop.carbide3d.com/collections/shapeoko-3-replacement-parts
you should need:
https://shop.carbide3d.com/products/replacement-shapeoko-3-motor-extensions
but the transparent connector doesn’t seem to be one from Carbide 3D — photo showing that part in its entirety?
c.f.,
Three photos of the z-plus connector:
That would connect to one end of the motor extension:
and then afford the same connector to plug into the controller.
Looks like I will be ordering the motor extension. Thanks for the information.
Finished up the z-plus conversion and everything seems to be working as it should. A special thanks to everyone who was involved in the process to get this done. Roger
