These days I need lots of light so I installed these corner led light strips.
Looks good. Added to my potential upgrade list.
Me too, Added to my list project…
I love it. Was also thinking about making a lip there to help better trap the dust in.
Now thinking about it, also making a port to hook up a vacuum to the side as well.
do they tie into the existing power supply or have a separate unit? look good!
Mine came with it’s own power supply but since they run off 12v you could wire it into the machine if you wanted to I am sure. I have not opened up my machine that far so I don’t know where they would hook up.
gotcha. I was hoping you’d save me some effort in wiring it direct to the machine.
You can totally use the internal power supply.
I don’t know what specific terminal it is on the nomad circuitry, only inspected it once so far. Another thought if that doesn’t work, is you could have them run off 2 different supplies but integrate it into the Nomads switch/button. So when you turn on/off the Nomad so will the lights. Just another option that comes to mind.
