Acrylic wall finish tips?
You might try cutting a straight edge that is 1 degree off axis; if the marks are about 1.5mm apart then I would say it is a limit of the machine resolution of 0.025mm/step. (or, replace your belts with ball screws and see if the spacing changes proportional to the steps/mm change)
