A link to this tutorial showed up in my Google news feed today, which means it’s likely been pushed to many others.
Engraving software is actually pretty simple since it’s mostly a 2D toolpath that only involves following a line. The most convenient software is our Carbide Create CAD/CAM software. It’s built for 2D machining, and it allows you to start from a blank page or import your own design to cut. Carbide Create is also totally free.
It’s all in the quote. Carbide Create is no longer totally free, and it’s confusing members of other venues. C3D has changed some, but not all, references on their site. This is a comment on one they missed, and Google pushing out references to the engraving information page will result in more people downloading and installing CC, and then discovering they can’t export gcode, and unnecessary ill will towards C3D. The last time I looked, and based on comments here, it wasn’t particularly easy to determine why it wouldn’t export gcode.
They could also change “built for 2D machining” to “built for 2D and optional 3D machining”.
I have Carbide Create V7 Free.
I have added a Tool, .75 Bowl Bit or Ball surface forming Bit. I am using this on a tray on the inside pocket edge.
I noticed this does not show up on the simulation graphic. I believe I knew this but, my question is, will this feature, or function ever be added to view in CC?
Maybe I’m not doing this right? I first created a pocket with a flat bit. Then using the newly added Ball Mill tool, I am doing a contour cut with “NO OFFSET”. In my head this should show rounding, YES?
It has the same pricing structure that it did a year ago when I started using it. Carbide Create is free, Carbide Create Pro is a paid version with additional functionality.
Given that this is a reference to their software on their website, I don’t see an issue with how they have this described. I’ll let them determine if they want to change the wording though.
Suitable feeds and speeds? What did you see needing changed? I use what C3D has for each bit, changing what was posted for #202, (which your duping the 202 and changing the diameter worked. I see the curving now. Thanks.)
What would be suitable for a 0.75 ball bit? I have no clue.
The previous policy was to encourage non-Carbide 3D router owners, which has changed. Try using V7 without a C3D controller, Carbide Create requires the purchase of a C3D product or a monthly payment. The article wasn’t C3D specific, and V7 can’t be used for free, as in producing usable gcode, unless you have a router with the appropriate controller. Totally free doesn’t tell the typical new user that they can no longer use CC on a non-C3D product and it’s drawing in novice users who are confused they can’t make the product work with their brand X router.
C3D needs to make their new policy more obvious, even “totally free for for ShapeOKO and Nomad users, subscription plan for others” would help those of us that do some volunteer support on other products. Not complaining about the policy change, C3D has every right to alter their policies, just how an abrupt change isn’t being being communicated very well. I was pretty vocal about recommending Carbide Create as the best free CAD/CAM software available to CNC beginners with another brand of router, and recommending ShapeOKOs when the inevitable “this is too limiting, what’s a better router to get” questions come up. Not making it clear that this is no longer an option is giving the newbies a bad taste. I installed Carbide Create and can’t get it to save gcode comes up pretty regularly, and even on the download page it’s not clear that you must pay a subscription fee or have a C3D router (without modifying the controller…) to use it. Better expressing this will prevent some of the ill will caused by the current situation.
All I wanted to do was point out a page that needed to be changed, since it was confusing. And I think @ehendrix posted in the wrong topic
