The problem is, these designs are workable because they assume the narrow kerf of a laser.
I looked into using such generators on our machines at:
There are a lot of other joinery options, esp.:
which is discussed at:
and which I looked into at:
The SO5’s optional overhang allows one to cut traditional joinery if one builds a vertical fixture, and are willing to commit to the additional operations which that entails.
I’ve been working on a joinery technique:
which has been successful to the point that I’ve begun a serious project using it — have the stock, and it’s mostly drawn up — should be cutting this evening or the next.
If you have a box style and dimensions (height, width, depth, stock thickness and lid style)
I’ve done sliding:
and hinged:
Let me know and I’ll gladly work up step-by-step instructions for drawing it up in Carbide Create.
If you have any other ideas or suggestions, I’d be glad of them.
