Best way to program a half round cut for a cigar ashtray edge
Good evening everyone! I’ve just started tinkering with our new machine and I’ve designed a couple of cigar ashtrays to be done out of various woods.
The initial program itself is flawless but I’m having a hard time figuring out the best way to program the cut in order to do the half circle notch where a cigar would rest on the edge of the ashtray. I’m using the base non 3D program at the moment.
I’m looking to get the notches 21mm wide x 10mm deep with a nice half circle profile. Is there a way to program this in the base carbide create v7? I would appreciate any insight or help, CAD is extremely new to me lol.
Our machine is the Shapeoko 5 pro machine with the VFD spindle kit if that matters.
Thank you all for taking the time to read and help out!
Tyler
Do you have a ball-nosed tool with geometry to match?
If not, you would need to use a smaller ball-nosed and a couple of passes and multiple lines as noted at:
if you get stuck, post your file and we will walk through this with you.
Use a large Ball End bit.
https://www.amazon.com/MEIGGTOOL-Cemented-Carbide-Woodworking-Diameter/dp/B095NKYCQV/ref=sxbs_sbv_search_btf?content-id=amzn1.sym.f15d2f09-357d-4995-986d-e924fbe183e3%3Aamzn1.sym.f15d2f09-357d-4995-986d-e924fbe183e3&crid=29C8LV1RNHXAD&cv_ct_cx=roundover%2Brouter%2Bbit%2B1%2F4%2Bshank&keywords=roundover%2Brouter%2Bbit%2B1%2F4%2Bshank&pd_rd_i=B095NKYCQV&pd_rd_r=5d4fe703-856a-459e-8fa2-0574fd956230&pd_rd_w=AHOVy&pd_rd_wg=Xa6WD&pf_rd_p=f15d2f09-357d-4995-986d-e924fbe183e3&pf_rd_r=5858HHB2AGBFDQP17HZ2&qid=1692759504&sbo=EO%2BcdOgoisx3waG5xqcZQA%3D%3D&sprefix=roundover%2Caps%2C172&sr=1-1-a61ee601-6e56-4862-a8a2-1d3da5a5406f&th=1
Awesome I will take a look and see if i can make sense of this, I’m going to attach my file into this reply as well.
I do also have a couple of tools, 1/4in ball nose end mill as well as 1/2 and 3/4 round nose router bits I just do not know exactly how to add the tooling info into CC
Ashtray geometric.c2d (1.4 MB)
I do have a 1/2 and 3/4in version of these, I’m just not fully sure how to go about adding the tooling info into CC
Awesome! I did a bit of digging last night and found some rough info on a round nose bit speed and feed rates so I entered it all and figured out how to create a tool path using a poly line finally lol. From my test rendering it looks correct, albeit square instead of the round cut shape which if I understand is irrelevant.
I’ve got a speed of 18k rpm and I modified the cut depth to 1mm per pass so I can take it easy when it comes to cutting cross grain and not blow chunks apart. I’m going to run a test tomorrow using MDF and see how it works out.
It should preview as round if entered as a ball-nosed tool.
Hmmm I might have missed something :thinking: potentially because I added it into end mill tab under my custom menu?
:man_facepalming:t3: idk why I didn’t think to add it there, late night CAD adventures lol. I will switch the tool info over to ball mill before I test run the program tomorrow lol. Thank you!
