Hello, I am new to the CNC woodworking community. I recently purchased a Shapeoko 4 XXL with the optional Bitsetter. I am currently have an issue where after I conduct the “home test” on step 5 instruction 5, I click for the SE button for the router to set over the right corner of the CNC. The CNC stops short of the right corner, and when I attempt to adjust it using the Y+/Y-/X+/X- buttons the machine does not respond. Instead I get a “busy” message on carbide motion.
I have sent an email to the carbide community support; however, it is a Sunday and wanted to see if anyone had seen this issue before. I have attached photos for reference. Thanks!
Your screenshot is showing the Increment amount set to .025mm, it may be moving but so slightly you aren’t noticing it. Try increasing that with the Increment + button.
Gentlemen, thank you for the assistance. Ed was correct. I needed to increase my increments. The machine was moving, but at such a small interval it was not noticeable. Now the real fun comes. Learning from the projects ahead.
