Just getting used to the Carbide Create 757 Pro version and loving the “Ramping” feature.
I have been exploring with the stock 20º vs 10º and both work great, especially for aluminum.
However, I have been noticing that the ramping will start way up high for a pocket cut path.
It looks to be as high as the “Retract Height” of around 0.5" (I need to watch out for work holding!).
My question is: how can I make use of this feature without having the ramping start at the retract height?
Ideally it would start near the surface.
With it as such now it adds quite a bit of time to my cut paths as it is slowly ramping through pure air for the first 0.5".
Is there a way to change how this works or maybe I am misunderstanding what is going on or there is a deeper setting somewhere?
Thanks!
