Based on this discussion, it seems like the capability to edit vectors in this way (joining objects and other less rudimentary functions) would be something that CC Pro should be able to do. The Vectric products, as an example, have pretty advanced vector drawing/editing capabilities, so there is usually no need to use another program when working with vectors.
Then let me be more clear for you- nobody from Carbide has said it would be a Pro feature.
I think it was mentioned in many of the messages in this thread that the vector editing improvements are all in the free version. (And all of the changes except the relief modeling for the past few months have been in the free version)
@WillAdams Thanks, I figured something along those lines for now. Just wasn’t sure if it was added yet. Didn’t want to send them out of CC if it wasn’t necessary but I was super tired, so figured it was just me.
I hope all that Observed Labor Day as a holiday enjoyed themselves. And those of you who don’t I hope your weekend was just as Grand.
OK then let me be clear too, I never said it was you or another Carbide person that said it was a going to be a Pro feature, I was responding to @rowiac who made the comment. Thank you for confirming it will be available to all versions of CC.
Created tabs for toolpath remain on screen after toolpath has been deleted.
One must save file, and re open to clear the tabs from screen
While editing/moving vectors if you accidentally double click one, it is thrown to other side of screen far away from origin.
While resizing vectors and you right click to pan screen it locks the pan function.
While Scaling vectors using resize function- if you click the outer edge of window to drag and re-size the vector can disappear, also caused program to not respond, left like this for 30 min, nothing ever caught up, I just shut down and rebooted the program. Did this 3 times with same results.
PRETTY, PRETTY, PRETTY PLEASE!
Would be great to see some Auto Tab feature in the future that would work with generic shapes, circle, squares, triangles, This would be so helpful when programming XXL to cut out for example 30 coasters at once, Setting 4 tabs per coaster equates to 120 tabs, and when you forget to offset outer profile for rough cut and must re do all 120 tabs manually.
Also would be awesome to be able to delete accidental tabs, like say I put it in the wrong place or accidently double stacked 2 tabs side by side. you could delete the ones you don’t want/need instead of starting completely over.
I understand the benefit of the auto-tab function you are asking for, but in the case of 120 tabs you mentioned, have you thought instead of using the blue tape/super glue method of holding your work down? If you do that, you’d need zero tabs.
when I cut them I add the tabs for the rough cut of an offset profile, then I do a full doc pass on original profile to remove scallops from rough cut, cuts off all tabs and they just sit there.
Ability to customize the cutting area. This would allow Shapeoko users to use carbide create to designs projects that can be cut on Shapeoko and Beaver CNC machines. I also believe there’s large untapped market for a simple yet powerful CAD program.
I’d love to see some more instructional videos on Carbide Create Pro.
Honestly some of us new to CAD/CAM software could use some step be step guides on each feature. I have been learning Fusion 360 via YouTube and I wish Carbide Create Pro had a teaching series of videos.
I don’t think we’d ever allow the default libraries to be removed (too many potential support problems there) but I can see adding a “Hide Carbide 3D Libraries” or “Hide Default Libraries” checkbox.
I added that to our request list for future releases.
Something I noticed in the toolpaths of CC, the feed rate and plunge rate are identified as inches. Since this could lead to confusion as it is a rate, it should state in/min.
yeah i can see it being an issue. maybe take something like vectric does where it allows the ability to remove them all, but simply click a button to import from website to restore default tool database but in reality, William pointed out that I can simply hide it which is fine. Just hate have to scroll thru a bunch of stuff I don’t and won’t use to get to what I do use for bits.
Loving the Update, going through it now to look for any issues.
One thing that would be nice is after creating a new Tool Library if we had the ability to rename the Library without having to Duplicate it to rename.
Found Error
The first Library Created is locked and you cannot add any tools. Consecutive ones are unlocked and you must restart program to unlock the first. Video showing the issue, which is apparently at random.
ps off topic is there any way you can take the extra 6 out of my screen name? it was supposed to be 6988 not 69688. If not it’s ok…
