Carbide Create Wasteboard Files
We have:
and there is also:
and of course:
at
https://docs.carbide3d.com/tutorials/project-wasteboard/
and for the Shapeoko 3: Shapeoko Threaded Table - Carbide 3D for which see:
Since I worked up a PDF, I thought I’d spare folks some work and provide a full set of files for a current version of Carbide Create which are hopefully matched up to the current rapid position coordinates (these may need to be adjusted — waiting on new wiring extensions to get my machine back up and running, and hopefully there will be a second set for the HDZ dimensions. Working these up now based on the measurements at: https://wiki.shapeoko.com/index.php/SO3_Function_Test#Distance_of_travel
  • Shapeoko 3: S3P001_100.c2d (203.8 KB) — note that the Y placement of the holes may need to be adjusted (would someone with the threaded table check against the rapid position points?)
