I feel like this is going to ultimately be a bug in the software. My SO5 is similarly randomly stopping mid cut (busy). It’s happened on every file that I’ve run today.
I appreciate your advice Josh. The laptop is a new HP. For grins, I turned all the windows power settings to the max, rebooted, disconnected from wifi, turned off Bluetooth, disconnected all USB other than the controller. No user apps running other than CM and task manager
CM still hangs at line 17. CPU shows <10% and memory at ~50%
I’ve run many jobs over the weekend and all of them have failed at some point. I ran my file normally and it failed about 20 minutes in (busy). I removed my dust collection from the equation and ran the same file. Again, it failed around 20 minutes in. I then did an air cut without dust collection and the router off. The file ran to completion, about a 45 minute cut. Then I ran the air cut again with the dust collection on and again the file ran to completion. I then cut the dust collection back off, turned the router on, ran the file again with just the router and the machine. The file again failed about 20-30 minutes in (busy) displayed on screen. I’m not sure what’s going on🤷🏻‍♂️. I ran two previous machines a Shapeoko xxl and a Shapeoko 4 pro. Never had any issue on those machines.
I opened up the log file while trying to run again. This looks very much like a comms error over USB. The hang always occurs when CM does not see an “ok” response
I tried changing the USB COM port from 9600 to 115200. The program ran much further, but still hung eventually.
Editing this post to avoid confusion. The following are current in January 2023 and not likely to be part of the issue.
$I results
[OPT:VN2,14,128]
[VER:1.1h.20190830:]
Josh, are you running Carbide Motion? CM build 578? Windows, Mac, Pi for the OS? Support asked for msinfo32 from my computer, but has not come back with any ideas yet.
If your SO5 is working, just trying to find the difference between my setup and yours.
I’m working on imaging a Raspberry Pi with CM today to try and see if there is a differential from Windows 11
I ran a project last night and it hung up once in around an hour of cutting MDF. After I restarted the machine and CM, I ran a ground from the grounding block to a plug with ad ESD cable. I restarted the same file and it ran to completion. I also don’t have anti-static dust collection hose. So I have that set to be delivered tomorrow and I will ground it.
Interesting concept. I measured from my grounding block (with the green/yellow bananna plug connected) to the power ground and it was ~1V AC
Pretty sure this is not the issue since the Windows laptop USB is floating with respect to ground and so is the Raspberry Pi. On the other hand, I’m willing to test since others have tried supplemental grounding.
