Hello! I’m new to CNC, but I’ve done a bit of 3d printing over the years, so I have at least some understanding of X,Y & Z. I’m using CCP V7software on a S5P 4x4. However, I am getting stuck on the rendering difference between what is shown on the 3d model, as shown here
What actually gets carved is what is shown on the tool path simulation.
I just can’t figure out why the 3d model shows it just how I want it carved, but the stars end up being cut as a positive instead.
I wish I could go back and show my 3d model component details, but once I hit done, it’s…done. I think the wave was .35" add, the stars maybe 4mm subtract, and my white stripes .5mm subtract.
Hopefully it’s just something simple I am missing, but after countless hours searching the internet & YouTube, I can’t figure it out. BTW, I saw similar title post, but could not figure out how to add to the thread since it was already closed… Thanks in advance!
Thank you for response!
I can’t fully wrap my mind around that. It makes sense, but I’m not sure how to not do it geometrically. I am importing a wavy image and then using a template on top for carving out stars in the location I want. My understanding was that if I lay my pattern on top my carving would fall within the pattern that is already there. (Making the stars track the angles of the waves) But maybe I am doing it incorrectly. Would it be more of an order operations thing?
In my imperfect brain I am doing it like every tutorial I’ve reviewed, but I’m probably not.
You may want to consider using a smaller tool, (so long as you don’t over-run the cutting flute length) or possibly a tool with a geometry which matches the appearance which you wish to cut.
Note for the cutout profile that you don’t want to cut a slot as narrow as the tool but almost 8 times deeper than the diameter of the tool and almost twice as long as the cutting flutes on the tool.
Ideally you would use a tool which has 1" of cutting flute length.
At a minimum you should offset by endmill diameter and cut as a pocket down to tab height or the penultimate pass.
Where possible avoid slotting and add geometry and cut as a pocket
and/or
Will, you are my new hero! While I still don’t completely understand how that made it work, I got it to based on your instructions. and I have some new resources I haven’t had the chance to review just yet. I will look at those as well. Thanks so much for your help along my new journey!
Here’s a pic of it roughing out now! I’ll have to go in a little tighter on a finish path with a 1/16bit most likely too.
Make sure that the smaller tools which you use have cutting flute lengths longer than the height of the most vertical feature which you will be cutting with them.
Absolutely! I will probably redo the depth of the stars and trim them in a millimeter or so with a 1/16 or 1/32 to make them pointy. But thank you so much for the reminder. This was my first test run on a 3d print so I don’t need it to look quite perfect.
Or should I consider using a 90/60 vee on the stars while going 1-2mm deep?
