Why would anyone laugh. I think it is pretty innovative the way you put it together.
@72begin and @Caffein8ted, thank you for sharing those pretty clever solutions! (I wish I could control my tendency to over-engineer things and come up with simple yet efficient solutions like those)
This challenge is off to a great start, I can’t wait to see the final drawing you submit to illustrate what those setups can do!
So my first attempt was going to take over 3 hours because the feeds and speeds where the defaults for tools in Carbide Create and this is the areas with the darker shading. However I decided to build a custom library called Wilson 4 custom tools and started playing with new tool settings but mainly stepover and feed rate to try and cut down time. That said obviously there’s little force exerted on the tool itself and the forces are basically the inertia of the machine itself and sudden changes in direction so what would be a safe max feed rate to go with and not end up damaging something? I had it going at 2000mm/min and then bumped it up in Carbide Motion but thought I should maybe ask before I get carried away.
Can you imagine that support call and would this be covered under Carbide’s the first 30 days mistakes are on us policy?:
Carbide Support: “Can you explain what happened to damage the shaft on your stepper motors”
Me: “Well I was participating in the Community Challenge #20 contest and had a tool running at a feed rate of 7500mm/min…”
Looking at:
If you run your machine at 10.000mm/min and somehow end up calling support, you could always argue that “@wmoy made me do it”
Granted, that’s the rapid feedrate and NOT intended to be used as a cutting feedrate, but sliding the tip of a pen over a sheet or paper is somewhere between the two (and closer to rapid-ing, I would say).
My official stance is to not go that fast and I’ll deny recommending it (but would like to see the effect of, on the quality of the drawing)
A quick update to my cityscape entry. I cursed the tool change as the coloring pencils I used was much harder then the pencil used for the contour, actually is was probably pointier meaning also longer but it ended up piercing the foamboard and caused some issues later in the job. That said I’ll probably have to attempt this again either without the tool change or never mind the foam board and just use a wood panel. In either case here’s my second attempt at toolpath art using the “Wilson drawing kit #4”.
(Edit: Despite the issue I had I can definitely say I’m learning and picking up some tricks along the way)
I call it Bold and Brash
Working with the limited Z height on the Nomad 3, I designed and 3d printed a mount based off of the chip fan that comes included with the machine. I wanted it to keep it simple and make it easy to swap out the markers.
To keep the paper down I used a glue stick and stuck it directly to the MDF. I couldn’t get the paper flat enough to the MDF using tape.
Here are pictures of the mount and an action shot. I’m unable to post more than one picture because I’m a new user
Thanks for your entry and welcome to the community @BDR_Manufacturing
I’m intrigued by the shiny/jelly look of the green part, is this just an optical effect or a special marker?
Just an optical effect. The markers are the cheapo dollar store ones
I have a Shapeoko but this jig was used to hold down veneer for cutting. I have a 2 inch spacing on my waste board.
Maybe you could something similar to hold down thin material.
Thanks! I’ll have to try that next time
I drew the following on Glass with my ShapeOKO, or actually more precisely I drew the following on glass using a drawing machine created entirely using my ShapeOKO and liquid chalk pens or Sharpies.
The drawing machine is a CoreXY idea using a Arduino/GRBL controller to drive two stepper motors (A and B - analogies for X and Y), and a model aircraft servo motor for Z. Hook it up and ‘treat it like a ShapeOKO’ and it draws. Output .GCODE files from whatever software you have, and provided the Z axis is organised to be ‘above 0 = up’ and ‘below 0 = down’ then it works.
The brief was to create a fun machine that is portable, could be ‘stuck’ onto a window with suckers and draw pretty much any artwork wanted, provided it can be presented as GCODE. The design should be adjustable in size, lightweight and credibly accurate. Where did the brief come from? Wanting something to do during lockdown weekends, and wanting to understand GCODE/GRBL in more depth.
Four carbon fibre rods (8mm OD) form the outer frame, held in corner blocks that hold them true but allow for loosening and size adjustment. The pen carriage runs on a pair of 6mm carbon rods that form the X axis and carries the servo motors for pen control. The belt is long, running around the entire perimeter of the machine in two loops, and tensioned on the pen carriage using a guitar string tensioner modified to turn a Gates GT2 toothed pulley.
I modelled up each piece as double-sided 2.5D parts, and cut them all out of two slabs of cast perspex. The amount of material removal results in a surprising amount of chips - and the need to improve earthing along the dust extraction hose to reduce static generation!
The above is the ‘machine’ crudely held against a mirror to test it out. I will tidy up the wiring and make an enclosure for the Arduino and Shield PCB that holds the stepper motor drivers.
I took the standard GRBL source code (1.1x on Arduino 328) and modified the Z axis control to operate PWM driven servo motors, which took some doing as the GRBL software uses almost every resource on the 328 chip, made some small adjustments to the CoreXY algorithms, adapted how tool-changes were received to stop needless errors, and it fits in the memory footprint - just. And it works!! Not bad for a first venture into tinkering with micro-controllers.
I found a very neat app on iPAD (Vector-Q) that does a very good job of converting any image to pastel artwork, or SVG line-art, as a compliment to CC or VC tracing where the actual business of producing the GCODE files happens. One thing I discovered about Chalkola liquid chalk pens is that the pens don’t like crossing ‘dried up lines’ of chalk - they clog up!! So I also experimented with creating artwork SVG line-art using the ‘travelling sales person’ idea of having a single, closed vector that never crosses itself - this is a huge rabbit-hole to get drawn into, but did serve as an interesting learning vehicle for how image conversion processing works.
Files for the mechanicals are attached. These are Vectric VCarve format. If anyone is interested, I can zip up and post the modified GRBL source code - just ask.
WP Pen Slider Cap 3D Rev-1a.crv.zip (186.4 KB)
WP Pen Slider Body 3D Rev-1a.crv.zip (371.4 KB)
WP Pen RC Platform Rev-1a.crv.zip (185.6 KB)
Window Plotter Corners Flip-Jig.crv.zip (155.7 KB)
Corner Bracket Scallop 3D Rev-1e.crv.zip (31.7 KB)
Corner Bracket 3D Rev-1e.crv.zip (3.2 MB)
Maybe this ‘Glass Drawing Machine’ is stretching @Julien’s rules a bit, but I thought you might anyway enjoy the project and its outcomes.
WOW! I am so impressed by the minds of folks on this site. Great job.
Me too!
Honestly the contests are a must see for all the creativity. Both admin created themes and user created content!
Good evening to all.
I never drew with my Shapeoko XXL before, although I often thought about it. And I had put an idea aside, which I took out again for the challenge #20.
I had this plan that I liked:
So I redrew it in polylines, and I found a solution to attach pens or markers on my cn.
I decided to draw on a 700x500mm black sheet, with a white pen.
I set a feed speed of 700mm/min for the outlines and 500mm/min for the pockets and writing.
I’m happy with the result, the lines are super clean and regular.
I just need to make a nice frame for it, and it will be great for decoration.
dessin lego 700x500 ligne epaisse 1.nc (60.5 KB)
dessin lego 700x500 ligne fine 2.nc (518.4 KB)
dessin lego 700x500 poche fine 3.nc (1.3 MB)
good luck to all
vivien
Would you mind sharing this file?
Looks great!
What provides downward pressure on your marker ?
Thanks, Bill
I decided to give it a shot and play with some Sharpies as well. Since Seattle now has a hockey team - officially - I thought I’d have my XXL draw up the logo.
I mean, that, and I just couldn’t think of anything else to draw…
I took some video as well, and will throw it up on YouTube and post it here tomorrow.
I used a Sharpie holder from Thingiverse, and Vectric V-Carve quick engraving function. 0.050" deep Z-axis travel and 0.10" line spacing.
Update to my cityscape toolpath art with Wilson, there was a bit of a mishap with the tool change on the 3rd blue tool but another attempt all the same. Not sure if I’ll have time for another go before end of the challenge but I think it’s still better then my last attempt.
Edit: just to be compliant with the challenge rules here are some pictures of Wilson at work. Also @Julien do I need to add the details about Wilson in this final post or is it OK if they are split among 2 separate posts.
It’s fine, thanks for the updated pics!
