Harry Potter Hogwarts Crest
For Christmas I made the Hogwarts Crest for my daughter to display with her wand collection. She is a Harry Potter fanatic, so this crest will make a great addition to her growing wand collection. I found an image of the crest and used carbide create to trace the image.
I used birch plywood with an advanced v-carve tool path. Used 1/4in end mill then switched to a 60 degree v-bit to finish up. Then used 1/4 end mill for the contour cut out path.
I cut of the tabs, gave it a quick sanding and cleaned up some of the fuzzies left behind. I used white acrylic paint for the first coat. Then used the appropriate colors for each house and also painted the back yellow.
Things I learned: I am not very good at painting. Trying to do the feathers on the eagle was hard for me with my severely limited painting skills. I liked the way the crest turned out, and my daughter is thrilled with it.
