Im looking to reproduce this simple design from an albulm cover. I thought maybe with the brains on here we could name what this is, if anything. I believe the bottom is wrapped with a band-aid.
(Foo Fighters - let it die)
TIA
Re-draw it:
Then using the re-drawn geometry, model in 3D so it will approximate the actual objects:
If you get stuck, post the file here and we will walk through it w/ you.
Perfect, ill attempt this for sure.
Any chance you know what it is?
Are you asking what the object is?
It’s a double edged razor blade with half a band-aid on it.
