Can you direct me to a more in depth tutorial that explains the reasoning behind why carbide automatic settings for a say 60 degree bit seem to cut quite deep into material . Is there a way to tell program to not cut so deep??
The wider the carve, the deeper the bit will go. Currently, Carbide Create does not have an option to set a max depth.
If you imagine the font as two lines delimiting each side of a letter, When calculating the toolpath, Carbide Create wants the bit to touch the two sides with the bit, it tries to bridge the gap between the two lines of the font by changing the depth of the bit.
The width of the bit goes from near zero to 1/2in for most VCarve bits we use but when carving the same letter, the 60deg will go deeper compared to a 90 deg and a 90deg will go deeper than a 120deg bit.
Work-around for the interior:
The same principle can be applied to the exterior:
EDIT: but instead, one may now use Advanced V carving:
